Suzuki dt6 outboard
w2much
I have an Evil rude with about the same issue. So think about it. The water pump is working You may need to pull the head see what is going on. Run the garden hose to the telltale. Flush with salt away. Run a hanger up the water tube. Run the garden hose up the water tube. Does it still pump fine after half hour but steamed also or does telltale stop and steam appears. ?
