Suzuki DT65 prop shaft bearing housing remvl
yanker
Hi everyone...
Was wondering if you really needed rotor remover slide shaft and attachment to
remove prop shaft bearing housing ?? I've tapped it, but it is not come off. Does anyone gotta good idea for me or just go buy the proper tool for the job. What I'm trying to do is to replace all the seals, o rings and gaskets in my lower unit because I'm having bit of oil leak. Is it good idea to try doing it your self or should it be done by pro? One of the dealer quoted me about $350.00 plus parts just to replace the seals.
Ron
