Re: Suzuki Fault Code 24
when you turn your key in the on position do you hear the high pressure fuel pumpif you dont check your vst tank.sometimes when hich pressur pump goes out motor will not start at all but if you keep trying to start it it will throw you a map sensor air code but if you get motor running ecm will reset itself
