Can I connect and run my Mercury 60hp 2 stroke from a Suzuki Fuel Tank?
B Barry Pritchard Recruit Joined May 22, 2017 Messages 2 May 22, 2017 #1 Can I connect and run my Mercury 60hp 2 stroke from a Suzuki Fuel Tank?
ondarvr Supreme Mariner Joined Apr 6, 2005 Messages 11,527 May 22, 2017 #2 The only thing that matters is the connection fitting on the end of the hose, so buy one to fit whatever brand motor you want to use and swap them out.
B Barry Pritchard Recruit Joined May 22, 2017 Messages 2 May 22, 2017 #3 Thank you ondarvr.......so the size..diameter of the connection should not matter then?
Alumarine Captain Joined Feb 22, 2005 Messages 3,757 May 22, 2017 #4 The connector(s) have to be the correct one for both the motor and the tank.
ondarvr Supreme Mariner Joined Apr 6, 2005 Messages 11,527 May 22, 2017 #5 Pick the Merc connector fitting for the end of the hose and you're good to go.
