Suzuki Hard Starting
GARY NOLAN
SUZUKI DT 30 HARD STARTING WHEN HOT WON'T IDLE
deejaycee hope you see this I SEEM TO HAVE LOST MY LAST MESSAGE I DID AS YOU SUGGESTED AND ADJUSTED CARBS RUNS GREAT NOW THANKS A BUNCH.I SEE YOU SUGGESTED TO ANOTHER CHAP TO DISSCONECT THE OIL INJECTION AND RUN ON PREMIX HOW DO YOU DO THIS THANKS GARY
deejaycee_2000
Re: Suzuki Hard Starting
Disconnecting the oil injection is easy, you need to take off the oil pump and see inside there is a little gear (pump's drive shaft) that connects the pump, take that gear out and fit the oil pump back, the rest you can leave as is, unless you feel like you wanto take the oil tank itself out, then just run it with pre-mix fuel 50:1 .......
