Throbbin Rods
- Joined
- Jan 25, 2003
- 213
My trusty old 1988 Suzuki is having an issue with the choke. It started binding up over the winter so I parked it. I took the carb apart this spring and it looks like they use a fuel enrichment passage as opposed to a butterfly choke. I freed up the little slider that is attached to the choke cable and lubed it a little bit. It worked fine for about a month, now it's stuck again. Is there a lube reservoir that takes care of this? Am I supposed to be lubing this regularly? I ahve long since misplaced the boks. Any help would be greatly appreciated.<br />thanks<br />bill
