I spun out my propeller Dec 30 on my Suzuki 140hp mod. 1988. I would like to know if I should be able to turn my prop shaft while its in gear.When I do I hear a clicking sound but it will still turn. Just wanted to know if after I get a propeller there is another problem, you see the motor ran for awhile after it spun out.When I run the motor on land in gear the prop still turns so I know the shaft is still hooked up. Help if you can.thank you
