citadel1995
- Joined
- May 2, 2010
- 22
Once again, I need some help and guidance from all of you gurus.
I have a 1979 OMC Ford 351 with 800 outdrive. The motor is toast. leaking water in oil, and oil spurting out of valve cover hole, water/oil mix coating the plugs, etc. etc. So I found a rebuilt 1987 350 fairly reasonable and wanted to know will the outdrive/bellhousing easily attach to the 350? what other types of modifications do I need to expect or should it be a fairly "simple" drop-in and go?
Thank You guys for your input! It's always helpful!!
mp
mp
