Is this an easy direct bolt on swap? Yes the ratio's are the same.
K-2 Chief Petty Officer Joined Apr 3, 2011 Messages 406 Sep 29, 2015 #1 Is this an easy direct bolt on swap? Yes the ratio's are the same.
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 50,234 Sep 29, 2015 #2 the 290 DP and DP-A share most of the same parts, so yes, should be able to. however dont you have twins?
K-2 Chief Petty Officer Joined Apr 3, 2011 Messages 406 Sep 29, 2015 #3 Yes, this is a different boat I'm thinking of buying, it has a 290A . I have a spare DP-A and wanted to make sure it would swap if needed. Thanks! Last edited: Sep 29, 2015
B billbayliner Chief Petty Officer Joined Jun 30, 2006 Messages 553 Oct 9, 2015 #4 As long as it is NOT a DP-A1 .
