swap lower unit merc 228 with 260?
arty007
are the lower units on a merc 228 and 260 interchangable? housing looks identical..
Bt Doctur
Re: swap lower unit merc 228 with 260?
Series`1 and Alpha`s will swap.but not with the GEN II type
Ayuh,... Should be the Same...
arty007
are they different as far as gear ratio? would it be better,worse,the same?
my 260 housing has a patch on it.. looks like epoxy and im wondering if i can replace it with the 228
Bt Doctur
The gear ratio`s are determined by the upper unit.
