superfets
- Joined
- Mar 6, 2017
- 139
Hi all, how is everybody?
So my first new to me boat came with a 1988 3.0 liter engine, sn# B832128. So i ordered the #10 service manual for 85-89. It will be here any day. But now that I'm buying a different engine to replace the original engine cause of the busted crankshaft I'm wondering the following. Will this manual work for both engines? I was told the serial number for the replacement engine sn# is 5636028. I can't seem to find what year that makes it? Can anyone enlighten me? Is the replacement a pre Alpha engine. And what service manual applies to that engine? Also, I plan to swap over everything i can from old engine to replacement engine. So the question is will the service manual suffice for both engines? Or is that a bad idea?
Now onto the swap itself. What problems do you think i will run into? Like i said, all that i was hoping to use from the replacement engine was the block and head. But i also fear that my manifold has a crack. I have yet to confirm how bad it is. But i may need to swap that also. What about the rest? Coupler, carb, alternator, power steering pump, distributor...ect. Let me know what you think, any and all opinions/thoughts are welcome. Below are pictures of both engines.
Thanks again everyone.
P.S. What should i do to the boat/engine to make my life easier later on before i put it all back together?
