I have just the plain jane Edelbrock Performa on my freshwater only engine. I bought the power package that I installed in my boat while it was still installed in a (organ donor) newer hull that had rotted out. At the time the engine was totally rebuilt zero hour motor that had been upgraded to Vortec by the previous owner. Doing the Vortec upgrade required a different manifold, hence the all aluminum Performa. It had a square bore to spread bore adapter with a beat up QuadraJet installed. I ended up swapping the Q-Jet out for a 1409 - the Q-Jet and adapter was a teensy bit too tall to fit under my doghouse.
As long as you stay out of brackish and salt waters, you'll be golden.
I spent a lot of time in the various year Mercruiser parts drawings finding a clean setup for the fuel lines, mounting brackets and linkage brackets. The 1409 Edelbrock is the exact same carb as the Weber that came stock in many Mercruisers. So you can find OEM parts and pieces where needed to make a clean and safe system.
Rick
