Hi, i was looking at my drive to get the number and discovered that it was originally behind a 140hp motor. Somebody just restickered over the original sticker. The boat is a 74 22' searay with the ford 233hp. The drive tag read 1.98r and the drive i'm supposed to have is 1.32r. The number is 4758500. I'm wondering if someone changed the internals out to the proper ratio. I did have a chance to run it before i put it away for the winter. With a 14x19 prop on i was turning 4200 at wot which is perfect as that's my max rated rpm. Fish finder said i was doing 46 mph but i doubt that's accurate. Is there a difference in the 4cyl outdrive vs 8cyl outdrive besides ratios? I'll be doing new water pumps, belows, gimbal bearing and trim sender in the next month. Is checking the ratio on an outdrive the same as checking it on a rear end. Rotate the prop and count the number of times the input shaft spins?
Thanks,
Jeramie
Thanks,
Jeramie
