swapping a 350 for a crusader
krisnowicki
Two part question. First I have an 83 350 and i have found a 89 crudsader 350. Would these two be inter changable? Would the alpha drive hook up to is the same and would all the accesories fit the same?
2 it will mount in my boat on the same two bolt mount right?
180shabah
Re: swapping a 350 for a crusader
Those two engines are of different vintages, short version they have a different flywheel, starter and coupler. If you get these parts with the "new" engine, then yes the rest is 100% interchangable.
5meter
Did you get the flywheel and coupler with the 89?
First I have an 83 350,alpha drive and i have found a 89 crudsader 350.
Ayuh,.......
While it's Doable,.......
Crusader is Not a drop in, Plug,+ Play motor for a Mercruiser............
180shabah
What are the differences that couldn't be overcome using components off of the old engine.
krisnowicki
i would be getting the flywheel and the starter but no coupler... but the mount is the same?
No,..........
If you Strip them both down to the Long Block configuration,+ then install All the Mercruiser parts onto the Crusader,......
Then you'll just have to deal with the Differences at the Flywheel........
MikDee
Banned
Aha! That's because the Crusader is an inboard engine, and the Mercruiser is I/O setup. Basically the same motor, but like bondo, & shabah said the newer motor has a different (newer style) crankshaft, hence a different flywheel, & coupler bolt pattern., and of course you'll need your old Merc style exhaust manifolds, & risers.
mtnrat
I understand the differences between pre and post 1986 engines. What coupler would be needed to use a post 86 in a pre 86 application. Is it the same for Merc and Volvo? If not what are the differences?
Ayuh,....... It depends entirely on What you're starting with...........
Old Mercs used a Crankshaft mounted Coupler,....
Later 1s used a Flywheel mounted Coupler......
If it's the Crankshaft mounted Coupler,....
They make 1 with the 3" bolt pattern for the newer crankshafts......
If it's the Flywheel mounted Coupler,...... You just need the Right Flywheel......
And,........ I have No Clue what Volvo uses,.... So,... I can't say......
krisnowicki
the reason i am asking is i have a rebuilt crusader here for 500 or i can get the long block from apido for 1450 that is the oem replacement is it really that much truoble to stip this down.. I have the orignal 350 from my boat...
tommays
well your dealing with the 12" VS 14" flywheel to the best of my understanding ?
As well as the problems that go with the correct starter
I have seen this come up many times and never seen and easy fix( like use flywheel X and it will work )
And just be sure Crusader spins the correct way as it could be CC or C
Tommays
Ayuh,........
It's a few hours time to Me,.....Along with a bunch of Gaskets,+ whatnot.....
But,......
We have No Idea of Your Abilities,+ Tools available to you.....
MikDee
Banned
Tommays
Rotation?, Good Point Tommays!
