Swapping engines 2004 90hp mercury to a 1989 125 Force wiring
2154Boy
I'm swapping from mercury to force. Does anyone have know how I could wire the force enginee to my mercury wiring that's already there so I won't have to buy knew wiring
2154Boy
Does anyone know what wires would go where cause the boat mechanic I talked to said I don't need a new harness
The Force power
IF I understand you correctly.... are you just swapping the ignition?? or complete power head??
Either way; Your "Mechanic" has it wrong!
up to 1999 Force/Merc. had certain components in common.
A 2004 for sure NOT
Chris1956
Are you installing the '89 to replace the 2004? Usually, folks do the opposite. If installing the newer motor, you should price new controls. I paid $130 for new Merc controls and wiring harness. It was plug and play.
The wiring for both motors is likely the same or real close, unless the Merc is EFI. However, I would expect you will need to have or make some sort of adaptor to connect the Merc harness to the Force harness.
On a related note, have you checked the compatibility of the mechanical part of the controls you want to use. Some motors have different "throw" for shift cables than others. Some push to close the throttle, like the Merc. Johnnyrudes push the throttle open. I have no idea what Force does.
If wanting to adapt the new control to the old motor. the simplest way is to cut both harnesses in the middle and use some butt splices to connect the wires. Both should use most of the standard wire colors. The Force has a hot light, and the Merc likely has a overheat buzzer. they likely interchange..
