Re: swapping engines from Ford 302/mercruiser to 350 OMC
351 is mostly interchangable with a 302. Same bellhouse, same exhaust manifolds, same engine mounts and spacing, and for the most part the engine accessories will not be a problem unless they mount up to certain holes in the head and to the water pump. Different intake manifold, distributor and oil pan though. One thing to be aware of on a 351, it has a taller deck height. What this means in practical terms, is not only is it taller, its wider. This might be a problem with your exhaust and maybe with other items in your engine bay. Its not a great deal bigger, but if your bay is really really tight, you'll want to be aware of it.
