Re: Swapping Outboards tonight
Yup that 90 is a v4 and a lot heavier than your 70 so be careful when moving/lifting it.
You will want to install the steering cable into the new outboard BEFORE you bolt it onto the transom. I usually hoist the motor onto the transom, slide it all the way over to the port side then install the steering cable. Then you slide the motor back over to the center and bolt it on.
Also make sure to properly clean out the mounting holes in your transom and seal them with fresh 3m 4200 when you are installing the new motor.
