Swim Ladder protection
model14
The swim ladder on my 1988 ThunderCraft restoration is teak (I think). I have attached a picture for your opinion. The boat will be in salt water most of the time and the swim ladder is continuously sprayed with water underway. What is the best protective coating I can use? I am thinking of just a varnish, and having to redo it every year or so. Do you agree?
Thanks,
Richard
DeepBlue2010
Re: Swim Ladder protection
One way to do it...
1) Clean with some oxalic acid
2) Sand smooth (220,320)
3) Apply multiple coats of Teak Oil.
You need to recoat frequently with this method.
Woodonglass
A somewhat more longlasting method is to clean as suggested above then apply the Teak Oil. After drying for 48 hours apply 2 coats of thinned epoxy (20% Acetone with epoxy) and then 3-4 coats of Marine Varnish (needed for UV protection). You could even sprinkle a little sand on the last couple of coats to give a bit of texture to the treads for traction.
model14
Is marine varnish UV protected, and regular varnish is not? Anything with "marine" on it is so darn expensive!
Woodonglass
Yup Marine Varnish has a high degree of UV protection. You can just use the Teak Oil (it's kinda Pricey too) but as stated you will need to apply it on a regular basis especially in a Saltwater environment.
greenbush future
Are you in love with the wood platform? my guess is a synthetic material might be a better option so you don't have to maintain this wood to keep it looking nice. Some folks don't mind the maint. I would replace the wood and never look back.
