Re: Swim Platform Replacement
Well...here's my plan...<br /><br />Having never glassed before, and looking at end-grain balsa sheets that are 2' x 4'and plastic lumber, I've opted for a different solution. <br /><br />I'm thinking of using 4 Architectural grade clear cedar 2x6x8'boards. They will be tongue and grooved on the edges, glued and clamped together, with G2 Marine Epoxy Glue by Industrial Formulators of Canada. The tongue and groove is necessary so that the 25" center-to-center supports can be spanned sufficiently enough for proper support strength. Once the glue is cured, the entire "platform" will be sanded to remove any excess glue. <br /><br />The next step will be to plunge route, through the entire 1 1/2" thickness, 12" x 1" drainage holes spaced evenly between the supports. <br /><br />Then, the "platform" will be cut to length, sides angled in for appearance, and corners rounded with a jig saw for safety. Once that is done, the entire ball of wax will be sanded smooth.<br /><br />The next step will be, to seal all surfaces with Gluvit Waterproof Epoxy Sealer. Gluvit can be pigmented for color. I'm looking for a white completed swim platform. A few coats should be sufficient. <br /><br />Now comes my dilema. I need a surface that is not slippery. Can I mix sand into the final surface coat? Or, should I cut some heavy woven (24oz or better) glass mat and lay that on? Does anyone have any ideas?<br /><br />Any suggestions/advice good or bad, would be greatly appreciated.<br /><br />Thanks,<br />DrBones
