Hello all;
Boat in question is a '76 Starcraft, 165 Merc i/o and MC1 Drive (Ser. 3647773). If I'm looking in the right place, I believe the trim switch and trim sender are removed from my drive?
I think the wires should be connected at the bullet connectors that are connected to either side of the bellhousing in black plastic pieces, but there are no wires going into them from the drive, and I do not see any switches on the drive.
My drive does tilt up/down, and I have the regular three button setup and tilt/trim gauge as well. Gauge appears to not be functioning properly, which I would guess would coincide with missing tilt limit switch and sender??
I rebuilt the dash and had to re wire most of the existing wiring, as it had all been cobbled together over the years. Before I did the dash/wiring, my trim gauge seemed to work. Now it doesn't, and that started me going through wiring/switches.
On the trim gauge, I have one red wire coming from the transom to the "sender" terminal, a white wire on the "IGN" terminal that goes to the Ign. terminal of the Ign. switch and a ground and a light.
I'm no expert on boats, and this one is my first, so if I'm totally off on what I'm looking at please steer me in the right direction!
Thanks!
Here are pictures of what I've got...
Thanks!
