Switch Wiring
D
DJ
Guest
OK folks, what is the best way y'all have found to wire two or more switches to one device: ie; bilge pump, aerator, etc.?<br /><br />I would like to be able to control the device(s) from more than one location independent of the other.
rickdb1boat
Re: Switch Wiring
Hi djohns,<br />The best way I can describe it is to wire it like a 3-way light switch. A little simple, but effective with the proper switches.<br /><br />
D
DJ
Guest
Re: Switch Wiring
Rick,<br /><br />Ahaaa! I was thinking about that. I have a hard time relating AC to DC. Your diagram cleared it up.<br /><br />Thanks. :)
Re: Switch Wiring
You can also just wire the unit with 2 or more complete seperate circuits.... as in;<br /> switch #1, power to the switch, to the unit, to ground....<br /> switch #2, power to the switch, to the unit, to ground....<br />and with a bilge pump, power to the float switch, to the unit, to ground.....<br />this way you don't need wires from switch to switch..... <br />When any switches are turned on, the power will backfeed to the other switches, But this has NO adverse effects... as a matter of fact, i wired mine this way, now the bilge pump indicator light, lights up even when the autobilge comes on.. good way to monitor any leaks...
crab bait
Re: Switch Wiring
as in a 3-way switch in a house ,, all it is ,,is a single pole double throw switch... <br /><br />they are a VERY common type toggle switch at radio shack... the same thing...
