ob343140 60hp merc 88' running rough at low rpm, runs good at med to high rpm. Cleaned carbs. Someone one mentioned that cranking the enging without the plugs grounded can smoke the coils or switchbox and the motor will still run but with the mentioned symptoms. I had never heard this and was cranking the motor to time it and didn't have the plugs grounded. Any input on this is appreciated...................Jerry
