switched to mercruiser alpha one gen 2 but kept omc trim motor
j.barba
i would like to know which hose is the high pressure and which one is the low pressure on the power trim motor? is the top one high pressure? mine is a 1986 renken with 3.0 litre gm bowrider can anyone help with this thanks
Re: switched to mercruiser alpha one gen 2 but kept omc trim motor
Ayuh,... The Hi-pressure side is the Up side...
Hook up the lines, if it goes up, on the Up button, ya got it right...
If not, reverse 'em...
j.barba
ok i'll try it thanks, it won't hurt anything it if doesn't work though will it
