slag
- Joined
- Jul 17, 2009
- 471
Hypothetically, if I had my two wires coming from the powerhead hooked up to the solenoid wires in the reverse, what would be the outcome?
Neutral button pressed = ?
Forward button pressed = ?
Revese button pressed = ?
I'm not thinking well enough today to figure this out on my own. I'm hoping I just had the wires switched over last night because what happened was, my engine started with the neutral button pressed and I stayed in forward gear. Pressing forward gear kept me in forward gear, and putting it in reverse actually put me in neutral which doesn't make sense to me. Reverse means both solenoids should have power so reverse should work with the wires hooked up either way I think.
