Switching from a RH to a LH prop
xsnoboard
I have a Volvo Penta AQ125B with a Volvo penta 270. I believe there is a RH prop on there right now which is shot. My boat came with a brand new LH prop. I was wondering if I could use the LH prop without changing the gearing.(use reverse to go forward etc...) If not, how hard is it to change the gearing and what does it entail.
Thanks!
Texasmark
Re: Switching from a RH to a LH prop
Check the dimenisons...dia/pitch to answer your question. The only reason for LH was for dual installations where you could balance out the prop torque.
Only problem may be some balance problems that will surface with the prop torque in the opposite direction, like the boat may want to list to the Port (left) side. If so, shifting weight around the boat could offset it.
Also, the trim tab may need to be put to the same degree of offset, but to the opposite side. Propeller torque in now coming in the opposite direction which could cause the steering to become an issue.
My 2c,
Mark
Texasmark
In addition to what Mark said, you can easily change the rotation on a 270 drive. Here are the instructions for doing so:
http://www.panix.com/~am_dew/270_change_rotation.jpg
Very tactful sir. Yes I did forget that on LH and RH installations, the prop shafts are turning in opposite directions so to make this work one has to do that.
My compliments,
Mark
xsnoboard
So Basically I just need to change the shift rod from position A to position B and I'm all set.
Thanks
am_dew
Thanks
Yep, that's it. I'd also replace the cotter pins used to hold the shift rod. As Mark said, you may find that your boat will list to one side after you do this...that happened on my boat and adjusting the trim tab did not help, so I switched it back after buying a different prop.
xsnoboard
Just to verify.... Should I ignore this part? Or should I be doing something with the shift control? I moved over the shift rod as it said.
NOTE: The rotation must not be altered by inverting
the control levers.
For both a left-hand and right-hand threaded propeller,
the control cable has a ?push? motion for engaging the
forward gear. Check and adjust the shift control according
to Part VII, points 8?14.
wellcraft19
No, by moving the "linkage" at the outdrive, you are NOT ignoring this.
It essentially only tells you that you MUST push the control lever FORWARD when you want to move forward.
Safety aspect since, if you did not move you linkage at the outdrive, you could just continue driving "forward" by moving the "control lever" towards the stern. If you at the same time happen to lose you your balance, you and other boaters might be in a very dicey situation with an accelerating vessel, possibly with a driver that is now overboard.
am_dew
EDIT: I agree with what Wellcraft19 said.
SparkieBoat
I guess I/O outdrives are different than outboard motors. with an outboard motor a LH foot is different because of the constant forward thrust. I found this out the hard way, I was taking a OMC outboard CR gear case apart and could not get the bearing carrier out, I torched, beat, banged, bent/broke 2 pullers, then I grabbed the prop shaft and it just pulled right out, shaft, carrier and forward gear all in one piece. so I guess on an I/O this is not the same.
xsnoboard
Well this was a waste of time for me anyways. The new prop that came with the boat is a 15 Diameter and 19 Pitch and it hits the exhaust outlet. The prop on the boat is a 14 diameter 19 pitch... The 15 seems alot bigger than 1 inch... It just BARELY doesnt fit.
I wonder If I can go with a 14.5.
Anyone know what would be best? I would like something good for towing skiers/wakeboarders...
SparkieBoat
need to know what your WOT speed and RPMs are..and what is the recommended RPM range for your motor???
am_dew
I'll help out with the last part of Sparkie's question. According to the V/P manual for the AQ125B:
Max RPM: 5100
Max Cruising RPM: 300-500 below the above max (or 4600-4800 RPM)
xsnoboard
Well when I use iboats.com to select a prop for my outdrive it shows a 15 diameter 19 pitch. I am pretty sure I have it on the correct way but it hits the exhaust. Seems like its only 1/8 of an inch too big
am_dew
As long as the prop hub is mated with the prop shaft splines, there really is no other way it can go. Well, you can put it on the shaft upside down but that would not cause it to not clear. If it's an 1/8 too large, I don't see that you have any choice but to find a smaller prop. As for the pitch, without knowing what the WOT RPMs of your boat are with a known pitch prop, it's not possible to say for sure if a 19 pitch prop is best or not. What kind of boat, length, and approx. weight?
xsnoboard
Actually if I put it on backwards it clears.
I have a 1985 Sunbird 17ft and I think the boat weights 1600
am_dew
Do you have any idea what WOT RPMs the boat went with the old 19 pitch prop?
My boat is about the same size as yours but with a 4 cyl AQ130C and a 19 pitch is perfect for cruising but my hole shot is not that great. If I were to pull skiers or tubers, I would switch to my 17 pitch and keep an eye on my RPMs to be sure I did not go over the max for my engine.
SparkieBoat
a set of trim tabs can really help pulling skiers, or just if you want faster hole shots and lower planing speeds. without changing to a lower pitch prop.
5t1cky
Would this also be the same on a 280 drive?
wellcraft19
@5t1cky:
If you are asking about "modifying" the out-drive to support a propeller with different rotation; Yes
