Lyndy
- Joined
- Oct 15, 2006
- 437
This is a continuation of a previous thread. I am still trying to get the Swivel Housing off so I can replace the Impeller. Of the 4 Bolts I removed from the Housing, three were caked with what I suspect is dried Permatex and were dificult to get out and the 4th had very little on it and had corrosion on the threads. I have put a Rubber Mallet to the housing without success. The number of threads I have read on this Forum and the OEM Manual did not indicate it would be this difficult to remove the Housing. One reply to my previous thread indicated that Permatex is holding the the Housing to the bottom of the Upper Gearcase. Any suggestions on this? Does the housing come straight up and off after the seal is broken or does it have to taken off at an angle after the Seal is broken? Some additional tricks or procedure help please before I continue to knock it's block off.
