Swivel Pin removal Mark 28A
Ron Maire
Ok Rodbolt, got it apart so I can see a pin with inside thread on top and a pin in slot. Looks very badly corroded. Pored gogo around top of pin, will have to fashion a puller using threads. I can only get heat to top, can't reach bushings. My unit not like anything in in the maual. The drive shaft housing and power head mounting base are a one piece casting and the pin doesn't look like anything in the manual that I can see! I had to remove the four dyna-float locking rubber mounts to move drive shaft housing and get at tiller braket and pivot pin Any more advise.
mellowyellow
Re: Swivel Pin removal Mark 28A
you might want to post questions on this old girl<br />here: http://www.aomci.org/aomc.htm <br />(antique outboard motor club)<br />doesn't seem we have many here who have exp. with<br />old Merc Mark motors. I sure don't :confused: <br />good luck,<br />M.Y.
alcan
Hi Ron<br />Let me see if I can dig up some good info for you. This will take me some time. I'll try and get back to you tonight.
Ron Maire
Thanks Melloyellow and Allen for your reply, will look forward to your message Allen if everything fails I will try that site Mellowyellow.By the way what is the HP on your projectX motor?<br /><br />Regards,<br /><br />Ron
