I changed my 2002 Volvo SX Drive Bellows Boot this weekend and want to report on the experience. It wasn't bad at all. I didn't remove the Pivot Housing or the Exhaust Bellows. I wanted to remove the exhaust boot, but didn't have the right snap-ring pliers. Did it all from the right side with my son holding the pivot housing up and turned full left. Had to be extra careful with the trim sender harness, the gimbal greese tube, and the grounding straps. One hand through the housing and one on the side and I was able to easily get it on and didn't have to force anything. Removing the exhaust bellows would have made it easier though. I did not use any bellows adhesive/sealant. There was none on the old one. After doing this, seeing the design of the boot and the groove on the Gimbal Housing, I can say that NO amount of sealant or adhesive is going to do any good if the boot isn't seated properly at both ends. If it is done correctly, that glue stuff will give you a warm fuzzy but really serves no purpose.
