sx cobra outdrive mounting and shift cable mount help needed
stang32
i cant figure out how this is supposed to be set up since the bracket will interfeer with the outdrive mounting properly from what i can tell. i cant find any photos or videos of anyone setting one up​
bruceb58
The second link is not for your outdrive. The first one is.
BTW...that little bracket that is around an inch long with a bolt through it is not supposed to be there. It is supposed to sit back in the slot a few inches toward the transom. The first picture in post#2 shows where it goes.
fetch
You also have a hose sticking out of the water inlet. That is not supposed to be there either.
stang32
yes bruce, thanks, i found that photo yesterday, the hose was there so i could run the engine and keep the cooling system flowing.
bruceb58
Hopefully, you weren't introducing too much air along with that water and the impeller didn't get cooked.
