tvogz
- Joined
- Jul 16, 2017
- 30
I have an SX-M outdrive. Last time the boat was out I noticed leaking into the bilge. Upon inspection, I found the u-joint bellows had a hole. The outdrive is pulled and parts ordered to replace the bellows and gimble bearing along with the other seals etc.
1: Is this likely the cause of the water intrusion?
2: In my haste to order parts to get the boat back on the water, I ordered the OEM bearing 21752712. Will this likely be the sealed bearing and what life expectancy can I expect without greasing every spring?
3: reading some other posts I see people saying that the seal behind the bearing isn't necessary to change out. Wouldn't the fact that I had water intrusion say the seal is bad?
Thanks in advance
Thanks in advance
