I have a 1999 Volvo Penta SX-M ,The trim would not raise but would lower,I put 2 New Relays in and it started working fine out of the water.Once i got in the water and ran the Boat for about 10 minutes i tried to raise the drive it started the same thing no movement up only down,I put a jumper on the Trim motor to raise it to get it back on the trailer so I know the Trim motor works in both directions. I have not tried any new relays again yet.What do you think my next step should be?
I also noticed that the Trim Fluid was milky so i put new fluid in and now its milky again and running over in the Tank.But No fluid leaks that i can see on the Out drive .
