Sync and Link 1988 90hp Johnson
montauk1
Can any body give me the correct procedure to do a Sync and Link on a 1988 Johnson 90hp
montauk1
Re: Sync and Link 1988 90hp Johnson
OK I guess its called a Link and Syncronization. does anybody have the proper steps. thanks
Rick.
it is well documented in the omc service manual. You should get one, you will use it far more than you might think. The linc and sync is too much typing and different for almost every model so not something likely to hit the Top Secret File either. Best of luck. Rick.
