chadbenton
- Joined
- Jan 22, 2007
- 92
1988 150 XR2 I need to redo my sync and link again. I am not sure if I did it right the first time. I am trying to adjust the idle stop screw, I have a seloc manual and it specifies to set the throttle cam at the edge on the stop screw boss. On the boss itself is a raised edge that will line up perfect with the cam. Is that where I should adjust the cam to. Also, should the throttle cam be making contact with the roller on the carb. throttle arm, so they begin to open exactly the time the timing is advancing, or is there a delay there. This is the only step i am having trouble with and I know if it is not right, nothing else will be. Any help would be appreciated...........
