Re: Syncronizing Butterfly Valves in 70 Johnson
17isme-<br />You sure the problem is your carbs being out of sync? The most common causes of your problem is an incorrectly propped motor or dirty carbs... also have you checked for fuel restrictions,etc? I adjusted my 60 johnny just as described above, but it did very little to improve top end rpms...did however make it much smoother from idle to plane (which was my problem that I was having) as all three carbs opened and transitioned at same time. If need to sync butterfly valves, I would think you need to do the entire sync and linc, you will need a manual. Good luck
