Syncronizing Carbs
ob
Re: Syncronizing Carbs
Hey capt Allen,You can do a search on forums for general procedure and check points of carb synchronization,however I highly recommend obtaining service manual on your motor to get the specifics.
Capt Allan
Thanks OB, I tried a search and got no results. I am looking around the internet for a service manual, not having much luck there either.
ob
Capt Allen, did you try here at iboats?
rickdb1boat
You can get a Factory Manual at the link below. They will get it to you in a couple of days!<br /><br /> Manual
generally you would loosen the throttle plates for each bank of carbs, then, holding the bottom throttle plate shut with a pencil eraser, tighten the screw, repeat for the next two carbs, then work the other bank. if its done right, all plates should be shut. when you give it gas, all plates should open at exactly the same time (all 6)<br />I do recommend you check the manual, as there are variations between models. the ois should be measured with special OMC diagnosis tools<br />to insure proper timing pickup.
Capt Allan
Thanks yall. All I need now is the serial number and I'm on my way.
