Synthetic trim fluid?
ZmOz
I think I want to try some synthetic oil in the trim for my inline 6 this year. (mods please don't move this, trim systems are all pretty much the same between brands) First, does anyone think it would be a bad idea to switch to synthetic in a 30 year old trim system? Second, I've heard of using both 30 weight motor oil and Dextron III ATF in the trim system...which would be better?
ZmOz
Re: Synthetic trim fluid?
Nobody knows anything about trim fluid??
Terry H
there's a dude around here that knows a thing or two about oils and I am certainly not he...but given the three choices you mention, I would use the ATF...that's what I used on my 25 year old 'rude a couple of years ago with no ill effects...just a Thought
Elmer Fudge
Yeah! I've heard of that guy who knows two things about oil,maybe if i yell he'll hear me,<br />HEY LUBY WHERE YOU AT! :p :p <br /><br />I changed my trim fluid a few weekends ago,i used Dextron III ATF, because thats what the previous owner of my motor used, it works just fine.
Freezebear
My 92 Johnson calls for power steering fluid and not to use motor oils or transmission fluid. I changed it to the Valvoline synthetic last year and it works fine. No problems at all with the hydraulic system, just the electric motor crapped out from worn out brushes.
^^bump^^ Lube's seems to be hard of hearing this weekend ... With the weather we had over the weekend I'd bet he was out boating :D
