sea monkey
- Joined
- Jul 26, 2006
- 13
Howdy folks. I just recieved some info that I have been researching for quite a while and thought I would share it with you guys. I have been trying to find out if I can increase the HP in my T-50 by exchanging the emmission control module. As it turns out, a T-50 and a T-60 are identical outboards, the only difference being the ECM. If you have a T-50 and put an ECM designed for a T-60 in it, your motor will now perform as a 60hp with no ill effects. The change out is simple to perform and takes less than 5 minutes to do. No other changes or adjustments are needed after the swap, other than possible prop changes due to the increase in HP. My prop currently is a 13 5/8 x 13 and I might have to play around a little to find the perfect pitch. The price I was quoted was $525.00, which to me is cheap for an extra 10hp. FYI.
P.S. I was told the same is true for the F series motors also ( 50hp to 60hp ).
