T-8 impeller change
Would like to change the impeller on my 2002 Yamaha T-8. Is there anything special I need to know? I've changed several Mercs and a couple Johnsons, but never a Yamaha.
Thanks,
Mike
rodbolt
Re: T-8 impeller change
its easy, just when you seperate the shift dissconnect make sure you completly remove the lower jam nut or it will bend the shift shaft guide.
other than that its simple.
