BobList
- Joined
- May 20, 2010
- 135
88 Force 125.. the coolant flow thru this engine is designed in such a way that even if the t-stat is stuck shut, you can look at the pee-holes shooting a good flow and be lulled into thinking everything is ok? My engine was running great yesterday, and I was giving it the how fast can it go routine, and died, fast. I think it locked up, blowing a headgasket in the process... it started back up ( sluggish cranking)a few minutes later, ran good, but with a lot of steam from the pee holes.. it seemed to have the slightest miss, though. It was hard to start a few times after that, cranking speed pretty good, and otherwise acted "normal". 'cept for a lot of steam from the holes.
I got it home pulled, the head, no obvious gasket damage. I also found out my O Heat buzzer must be inop. Cylinders and piston tops look ok. #2 cylinder, piston and head area dry, and clean, the rest were oily, normal looking. Water jacket area around cylinders seemed dry, considering it was in the water 45 minutes previous. I'm gonna do a new gasket, compression test, boil the t-stat to watch it open, or not, , and hope for the best.
So, basically, can you overheat due to a stuck t-stat, even though there is good flow from the holes?
Bob List
Bob List
