T-Top Installation
eddy2419
I finally found a T-Top at a reasonable price for my 21ft Wellcraft CCF. It was built for another boat and will require some welding. When mounting to the floor, will large screws into the floor, which is wood backed, work or am I just asking for trouble. There is no access from below so i would have to put in a couple of access plates to be able to use bolts. When using bolts is a backing plate recommended?
Thanks
bajadude
Re: T-Top Installation
Thanks
bajadude
Thanks [/quote
Thru-bolting is obviously best, but not always practical. I have had t-tops professionally built and installed (Pacific Yacht Towers, San Marcos, CA) that were screwed/lag bolted to the wood core deck and they held up fine. These had brackets which also attached them to the center console itself and add valuable stabilization and strength. These are easily thru-bolted. Since you are having welding done anyway, I would advise you consider adding this type of bracket. While you are at it, add backing plates for outriggers, radar and a tab for a deck light if they are not already on there.
eddy2419
Thanks for the reply!
I'll go with the lag bolts and if they start to pull I'll get out the saw. Should I use expoxy or sealant under the feet? It has stand off's on both sides I am going to get fitted. I'll use substantial backing on those since the CC is fiberglass only. It already has 5 rod holders, anchor light, outrigger plates and spreader lights. I doubt I will ever mount a radar. It was a scratch and dent from a local boat plant for $750. Probably $3,000 or so new. We are a long way from salt water so they did not have a ready source to get rid of it.
eddy2419
First ime I ever understood how to put on canvas! Thanks for the great post. The canvas is good but the rope has some nicks, is black and is really small. This will be a good winter project.
