T8 throttle?
Coonshrimp
I've got a sloppy throttle on my T8. It acts like it won't return to idle. take the cover off and it works if I push the linkage back.
1- how do you properly adjust the cable? Should both sides be tight?
2- how do you get the return working properly?
Thanks!
Coonshrimp
Re: T8 throttle?
Actually, got a little more info here:
Started having problems after the boat sat for a while. Would not warm up quickly, and would not troll at the desired speed without a varying RPM and sometimes would die.
I cleaned the carb out, and it is 90% better but still has an occasional varying RPM and will not back down on it's own.
The carb appeared clean, and I did not see any obvious varnish. The small jet orifices appeared to be fine.
Got to get this thing running!
