Tablet at control/guages for boat
biglurr54
Has anyone else used a tablet for their boat. I am going to install a nexus 7 i have laying around permanently on the boat. I have a speedo app that will give me exact speeds. I can set warnings and ranges so un experienced drivers can pull me wake boarding and they will have green red and yellow screen flashing the speed so they will get in the sweet spot for that. Then I will add a bluetooth depth finder. All the while I have navtronics charts, google map and earth, and spotify. I plan to wire it to my amplifier remote wire which is wired to a switch on the dash.
They have automation apps for free that will put the tablet to sleep when the power is turned off so the battery will last forever. Then when the power is restored it will automatically set all the parameters I want and start the speedo app and spotify will start in the background.
Any one else do this? Any other apps i should consider?
there isnt a tablet that you can read in direct sunlight, and most are not water or moisture resistant. However its your boat, do what you want.
midcarolina
I think lot's of folks use their tablet boating...... think many use something like a ram mounting system, I would guess many remove the tablet from boat when stored.
I might also consider something like an otter box for it too.
H20Rat
Although I'm all for tech, I absolutely loath all-in-one vehicle integrated electronics. Menu function 3, scroll down, swipe right 3 times, swipe down. NOW i can adjust the volume of the radio... Or I can just turn the volume know.
And combine that with bright sunlight on a tablet, and you will have a very frustrating user experience for the sake of a cool factor that lasts about an hour.
midcarolina
Different strokes.......... I use my Iphone everytime boating, weather it be playing music or using navionics........just set brightness to full, set auto lock to never......
you dont boat in the Florida Sunshine do you.
gddavid
I understand where you are coming from completely and have thoughts and experience to share but I would caution that a device on the dash is probably not going to make your boat dummy proof for others driving your boat. A new driver needs to learn to get their head out of the boat to stay aware of their surroundings. This past weekend I was fiddling with the tablet settings while using it as a chart plotter while trolling and it was distracting enough at 3 mph and I consider myself to be pretty experienced.
I have found using the tachometer as a guide is the easiest way for a new driver to maintain the right speed for a wakeboarder. A perfect pass or similar cruise control system is probably the best route to go as far as getting a good pull from a less experienced driver, perfect pass does not recommend their produce for my engine package (3.0) otherwise I would probably go that route. I am fortunate that I have a good freind who rides with me most of the time who drives the boat well.
I have run MX Mariner on an ACER Iconia A200 which is a 10" android tablet with gps. I have found that the screen brightness has to be cranked up all of the way in order to have good visibility in daylight which definitely affects battery life. I also found that if the tablet went to sleep it would rarely recover the GPS signal without being restarted. To avoid this problem I changed the sleep setting to 30 minutes of inactivity before going to sleep. I was only using the tablet as a chart plotter and not trying to run other instruments through it. I was infrequently touching the tablet because I was trolling and using the tablet to see contour lines and bottom features, but rarely needed to touch it for any reason, so it was falling asleep and losing the gps signal untill I changed the settings around. I had the tablet charging through a 12V outlet/usb adapter and with the brightness cranked up the charge was still going down, I believe the contacts in the outlet were dirty and this could be fixed.
Like you I believe there is a great potential to use a tablet to achieve what would otherwise require a small fortune in marine electronics to accomplish but I wouldn't rely on it heavily until you have all of the bugs worked out. I think the biggest challenge would be displaying all of the information you want at once or to be able to toggle through them easily without them missing a beat. For example if I was using the tablet to display a blue tooth based depth sounder, the tablet I was using wouldn't be able to display that and the navigation app at the same time. I would focus on using the system to augment your existing instruments rather than replace them.
Please post back with your results. I am particularly interested in knowing how the Nexus does and if you can switch apps without the navigation losing it's position. The Acer I have been playing around with is my parents, my wifi ipad does not have gps (which is really my wife's) and I am trying to decide whether to buy a blue tooth gps for the ipad or a reasonably priced android unit with a gps like the nexus 7.
I think there could definitely be a market for an app which integrates and displays all of this seemlessly and capable of expanding to include audio, ballast systems, and whatever else your heart desires.
oldjeep
My Malibu has touch screen controls and a digital panel for most of the gauges and the last thing I would do is intentionally put a touchscreen in a boat. Its just more stuff to go wrong, a splash of water can actually "press" a button.
Ned L
Don't get me wrong, ..however, .... I so want to say "if you want to play video games then please stay home in your living room. If you want to go boating, learn what you are doing."
Chris1956
Gee, a setup like that would last a week, maybe, here on the Jersey Shore. The salt would kill it. Heck the salt regularly kills my stereo equipment, in my living room.
midcarolina
Navionics marine & lakes........but I think the new version is just called marine but it's the same app.
It cost like 9.99 but it is worth every penny..... there are several videos about it on youtube.
southkogs
Dunno' that I would install a tablet directly into the boat, but I have been using that Navionics App on my iPhone on my boat. It's pretty slick for what I need. I would be hesitant to trust it out on big water, off shore or where I navigate purely by chart. However, on the lakes I run on (pretty big impounds) it's been a nice app.
I did use it the other night to navigate in the dark for about 6 miles on a stretch of the lake that I was unfamiliar with. It was within about 30 feet of "dead on" when I tested it in the daylight a while back. (I posted a little about it here: http://forums.iboats.com/forum/boat...otors/663826-active-captain-garmin-blue-chart)
MidCarolina is right - for $10, it's worth a look.
Bubbasboat
I took your advice midcarolina and bought the app. Did have to buy the map upgrade to get the most out of it for my usual water. Going out tomorrow so will get to use it and really try it out. Playing with it on dry land tonight, so far it's a nice app. Thanks for the advice!:D
H20Rat
Except it completely screws with your night vision... Head down watching the gps when you run into the idiot without nav lights. Need a phone with an OLED screen that actually dims down, otherwise the backlighting is too bright. At least in my experience, most gps/fishfinder units will dim down enough for safe night usage.
midcarolina
It took me a little time to learn it.....Well I am still learning things about it........Like if you are using it to navigate to a waypoint tap the gps icon bottom left and the map will auto rotate to your direction of travel the gps speedo works good also...
Glad i could help a little
midcarolina
They got these new fangled contraptions they call Iphones...... they where so smart when they where developing this new contraption that they installed this neat feature called a dimmer..........can you believe that you can actually dim the screen..:eek:
southkogs
Well sorta' - I didn't put the effort into dimming my screen that night, but the iPhone has both an auto-dim feature on it and you can further dim it manually. So it probably wasn't as bright as you're thinking (I keep my screens fairly moderate anyway). Not quite the same as an LCD, but still there's quite a bit of control over the screen brightness.
More to your point though, the iPhone screen ain't all that big. In my case I just take my "holder" out of my car that let's me mount it on the windscreen and make it more of a "heads up" device. It is a little tough to see at that size, but like I said I'm not using it that often for navigation.
