I have a 1990 4.3L. 190 HP. New 14X19 prop. Max rpm wot has been showing 3400. Found that the switch on the back of the Tac was dialed to 4cyl. Tried to change it to 6 but the tac does not work at all at that setting. At 8 cyl setting it reads way to high ( 5-6K- at 3/4 throttle).
Does anyone have any idea what the tac at 4 cyl setting calculates to a usable rpm speed at wot for this engine? What I'm trying to do is see if the engine is operating at its best at wot.
In the 18'8 boat I'm getting around 38mph at wot with that prop and two adults on board if that helps.
Thanks for your vast amount of wisdom here.
