Folks... I may be able to help us out with this tachometer issue we have with the 20 pole tachometer for our Force engines.
I think I understand the problem.. tell me if I am wrong.
Our engines have 20 pole magnetos on them. Every revolution, we output 20 pulses to the rectifier.
Modern tachometers are set up for things such as 6, 10, and 12 pole.
I think I can design a simple circuit that would allow us to use a standard 10 pole tachometer. All we need to do is to take the 20 pole signal, and divide it by two, then output the signal to the tachometer. However, I need your help....I don't know enough about where the tachometer interfaces to the engine / rectifier. I'll need to hook up a scope to measure the pulses and see what sort of conditioning I'll need to do to divide and buffer out to the tach.
Can somebody tell me where on the rectifier (or engine terminal block or whatever) the tach attaches to? Does it attach to the input of the rectifier?
Thanks...
Frank
Thanks...
Frank
