tach cutting out
albass
today I noticed my tach running around 12 to 1300 rpms then she went down to 0 she did this twice lasted about 1/2 min to a min time wise would this be connected to my not taking gas when she's warm and bogging on take-off only after she's warm 91 Fastrike J150GLEI
mthieme
Re: tach cutting out
When I saw the title, I was thinking wire connection somewhere.
I wouldn't think that the symptoms are related, but...do they happen at the same time?
The bogging obviously is fuel related. Have you checked anything yet?
albass
not so sure it's fuel related because it only does it after it's warm and I've checked everything changed fule line, plugs gas water separator ,rebuilt carbs and did a linc and sync.Only does it after warm and has a low idle skip sometimes high speed is great no bogging or skips run hard 60mph no problem 5500 rpms
mthieme
You had a problem a while back with this puppy.
The powerpak was mentioned? Did anything happen with that?
Is this still the same problem?
The low idle skip symptom sounds like a carb to me. I know you've rebuilt them, did everything go okay?
