tach & Depthfinder
Tonja
I just put in a depth finder 1 month ago. The last time I took out my boat, Yesterday. The battery was dead. The depthfinder came on but not enough juice to start the boat. A fisherman let me use his battery to get my boat started. But when I hooked my battery back up I noticed that my depthfinder no longer turns on and my tach starts at 7000 rpms and goes backwards when I am giving the boat power. The battery did charge up and It is a new battery. Any Clues ??
Gunny77
Re: tach & Depthfinder
Humm,<br /><br />My dealer installed my depth finder wrong, hooked it up to a continouse power source instead of to an accessory power source. I caught it before it killed the battery while sitting. I have seen electronics act wierd when they try and work, but there inst enough power to make the work properly.
Tonja
Thanks Gunny 77 I will try to look at my power source. I am kind of electonicaly challenged.
roscoe
Your depth finder probably should be hooked up to an always on source. That way you can use it while drifting, or using a trolling motor or kicker. The key is to switch it off or disconnect the power with a battery switch when the boat is not in use.
Tonja
Any Ideas why my tach now starts at 7000 rpms and goes down to 5500 when I am wide open now, I am stumped. I can't find any blown fuses. I am going to install a power disconnect. I think that is a good idea. I put my depth finder on a different power source and it still didn't turn on. How could swithching the batterys while the motor running have this affect on the finder and the tach?
roscoe
You triggered my memory with your last post. It sounds like you used the other guys battery to start your engine, then disconnected it and hookud up your battery, while the engine was running. <br /><br />OK, brace yourself, you cannot disconnect the battery from a running outboard. The engine must remain connected to a battery whenever it is running, or ... damage may be done to your electronics. The rectifier I believe. This was posted here recently. <br /><br />This is also why if you are running a 2 battery system with a 1-2-both-off battery switch, that you only move the switch with the engine off.<br /><br />Hopefully someone will get back to you with the specifics.<br /><br />You may want to post a new topic, " battery disconnect while running-ooops", may get someones attention and a quicker response.<br /><br />I will look for the post that gives this info and copy it here if I find it.<br /><br />I found several posts like this:<br /><br />
You can't run your engine without a battery attached, even for a moment, without doing damage to the charging system. You can jump start from another battery through your current battery.
And:
you will damage the diodes in the alternator and rectifier.
The alternator produces AC current, which the rectifier converts to DC for use in charging the battery. The main cables of the wiring harness (the large red[+] and black[-]leads) are the conduits -- no additional connections. Don't run the motor without the battery connected or you will damage the charging system.
"Could a bum rectifer drain a perfectly good battery in say 2 weeks without running?"<br /><br />"yes its possible and easy to prove. just take the neg. batt. cable off and install a dc ammeter between the post and cable to check for drain. if you see some drain, disconnect the rectifier unit and see if drain goes away."
roscoe
Also recall reading: when you disconnect the battery from a running outboard, the power from the charging system has to find a place to go. This could be what damaged your depth finder.
D
DJ
Guest
Tonja,<br /><br />Ditto, rosco.<br /><br />You probably cooked the rectifier.
roscoe
It may have been already cooked, or on its way out, before the jumpstarting incident, or depth finder installation.
Boatist
Tonja<br />When you disconnect a battery with the engine running you remove the load and 12 volts can go to 1000 volts or more. Light will become flash bulbs electronics that are turned on will burn up. If your motor has a alternator I be suprized if the alternator is still good and also the voltage regulator. I am suprized your battery charged. Check your depth finder for a inline fuse or a internal fuse I think that is your only hope.
peterbo3
Tonja,<br />Possibly a little late with this advice but it is a good idea to install a voltage spike protector between your power source (battery) & all your electronics excluding your engine instruments. Voltage spikes or power surges can occur at startup & standard fuses or circuit breakers may not prevent your sounder or radio going south. Your computer is probably running through a power board with this sort of protection. If your tacho is playing up after the jumpstart I am with the rest of the guys-does not sound good & will not repair itself. <br />Regards,<br />Peter.
