tampaskiffer
- Joined
- Aug 29, 2005
- 6
I have a 2000 40hp johnson and have a omc tach that idles fine (800) until throttled up. Than it drops to zero and stays there until brought back to idle. I have ck'd all grounds and ck'd to see if I am charging 12volts while cruising. According to volt meter the stator is charging. I have read somewhere that adding a 1/2 watt appx 2000 ohm resistor between sender and ground terminals(on tach) that this would resolve the issue. Anyone have any luck with this or had the similar problem? Thanks ya'll. Jeff(tampaskiffer)
