Re: Tach/Dwell meter
I realize this is a really old thread but it still comes up near the top when searching for info on how to use an automotive tach/dwell meter on an outboard and I believe the info stated above is incorrect. I believe that you CAN quite easily use an old auto tach/dwell meter to measure RPMs on a 2-cycle outboard. Post if you think that something below is not correct.
I was trying to find a way to read the RPMs on my 1975 Evinrude 70hp, 3-cylinder. After about 2 hours of reading through posts here and elsewhere on the Net I learned that the tachs read the number of electrical pulses. Auto tachs count 2 pulses for 4-cylinder, 3 pulses for 6-cylinder, and 4 p for 8-cylinder. The OMC 3-cylinder motors have a 12-pole charge coil, thus 6 pulses coming from the charging circuit. If you set an old auto tachometer for 6-cylinder, hook the red lead to the charging circuit, the black lead to ground, then it should be able to count the number of pulses and give a reading that is double of the accurate RPMs. So cut the reading in half and you have the actual RPMs, right?
I would also think that you could use this method also on any 1, 2, 4 and 6-cylinder outboard with an alternator. You just have to find out how many poles the alternators have and figure out the correct tach setting and multiplication factor for your specific engine/tach combination. Sound right? For info on how many poles your alternator has you can reference the Teleflex tachometer install instructions. There is a chart that lists the number of poles and pulses for most alternator-equipped outboards. Here is a PDF of those instructions:
View attachment TachInstallationA.pdf
For those of you who are asking where to attach the red lead take a look at the other info on the Teleflex tach installation instructions. It gives 2 nice diagrams of attachment points for tachs, one for outboards and one for I/Os and inboards. I used the yellow/grey wire attachments on the terminal block on my 1975 Evinrude 70hp and it worked nicely.
