Can you use a Tach Dwell meter,when switching to the tach side to set RPM on a OMC 5.7 engine?
3 34 ford Cadet Joined Sep 20, 2011 Messages 28 Aug 26, 2012 #1 Can you use a Tach Dwell meter,when switching to the tach side to set RPM on a OMC 5.7 engine?
projo198 Petty Officer 1st Class Joined Jul 7, 2012 Messages 317 Aug 27, 2012 #2 Re: Tach Dwell meter 34 ford said: Can you use a Tach Dwell meter,when switching to the tach side to set RPM on a OMC 5.7 engine? Click to expand... I used one to set the idle on my 2.3 because my dash tach doesn't work. So yes, same thing.
3 34 ford Cadet Joined Sep 20, 2011 Messages 28 Aug 27, 2012 #3 Re: Tach Dwell meter Thanks for your help!
projo198 Petty Officer 1st Class Joined Jul 7, 2012 Messages 317 Aug 27, 2012 #4 Re: Tach Dwell meter No prob!
