Hi I have a 1992 65hp WMLE. I put a tach on it last year and the grey wire was dead. Did some research and found out I can use the yellow wire from the stator and that worked fine for a few weeks then intermittently would die. Thought it was the tach so i tried another but similer problems. System dont appear to be charging while the tach isnt working either.
So if im taking the signal right from the stator and that tach isnt working then the stator must be bad right? But If i check voltage across both yellow leads I get 30+ VAC even while the tach isnt working? This doesnt really make sense. Could it be that my stator is ok and a bad rectifier is causing all the inconsistent results?
